Omron CX Programmer Question
fredjohns
Dec 2008
Pennsylvania
119
When I bring up a program using CX programmer, the program comes up and all contacts have names on them but no I/O address. Is there a way to get the names and I/O address to show up for each contact on the program.
Yes, CX-P is very configurable.
Go to Tools, Options, Ladder Information and set it up how you want.
Also under Tools there is a section Keyboard Mapping - that is really useful. Set up short cut keys to whatever you want however you want. Excellent! Almost throw the mouse in the bin.
Your actual configuration (show address only if name empty) saves the screen space and probably is worth to be preserved.
The physical address and comment are always indicated at the bottom of the screen for the cursor highlighted device.
It depends on what you like. I generally do not program with symbols but numbers - the addresses shown are essential for me.
When I pull up some of by backup files using Cx Programmer 6.1 and try to go online I get a pop up saying "Modem Port Has Been Selected.Do You...
3,640
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
371
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
736
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,952
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,054
