Modsoft Software
PLCSiemens123
Mar 2021
NY
I am trying to locate a copy of Modsoft in order to program an older an AEG module. Unfortunately Proworx is not functioning correctly in order to program settings to the unit.
WOW. Last time I used Modsoft, it was loaded off floppies and ran in DOS mode on XP, and I needed to have an old motherboard since it controlled the UART directly and would not use the 'new' UARTs that had a FIFO for buffering. Do you have a VM that you can load it onto if you find a copy?
You need Dos Box
https://www.dosbox.com
We still support the old 984 motion controllers.
How you Peter have configured dosbox that serial connection works for modsoft.
I have tryed it with several different cycle speed and serial settings.
Modsoft online connection is working only couple second before timeout errors, no matter what settings I have maded or changed to dosbox configuration file.
Can any one let me know how to deactivate all STEPS in modsoft sequential Function chart ..
3,987
Hey all, I am trying to communicate with an old PLC using Modsoft. It's a Modicon Quantam 140 113 03. I am using Modsoft and whatever I try, I...
1,479
Hi i am starting to learn PLCs. i have a quantum modicon (Electric Schnieder) PLC and i am using modsoft. i would like to know how can i set and...
2,229
Hi all, I have some issues with a Modicon 984-385E on a machine we recently acquired. The unit was operational before it was moved but the genius...
27
11,462
Hey guys I need some help here, I don't have access to Modsoft as I presume this program was created in. I tryed locating Proworx32 on the web...
3,214
