ceilingwalker
I am about to undertake an upgrade like I have not done before. I have a contrologix PLC, 6 Kinetix6500 drives, 3 RIO's with point I/O, and 4 PF-40's, all connected to one machine. It currently has RSL5000 v.21.06 running and I am going to update it to Logix Designer v.31. I realize I will now have to flash the CPU, my coms modules(?), probably my VFD's also however, will this require any changes to the actual code that is running this system? I am making an assumption that the Kinetix6500 control modules will be able to be flashed up to more current software but don't know how to tell that, or if that is even an issue(?). If I sound a little frightened, it's because I am! This is a vital part of our production so I am doing my due diligence and spending as much time as I need to make sure this goes as smoothly as possible. I am certain many of you folks here have done this multiple times, which is why I am asking. Thank you much.
