Connecting AB PowerFlex 525 to Leeson Capacitive Start Motor?
DerekG_RIT
Mar 2021
MA
Hello everyone,
I am new to this site and relatively new to PLC have had a few college courses. I am now working on my Masters Capstone Project and am trying to control a old Lesson (See attached Pic for Name-Plate of motor) capacitive start motor with a AB Powerfelx 525 (See attached pic for serial number of Powerflex).
I have a few questions,
Is this possible?
I follow the General Grounding Requirements from AB from the 525 Powerflex manual, but I continue to get a Grounding Fault whenever I power on the motor and the 525 together. Any suggestions?
Thanks for your time,
DG
The motor is a single-phase device (hence the capacitor start descriptor in your post). The PowerFlex drive puts out three-phase. The two are not compatible. You need a three-phase motor if you are to control speed and direction with with a variable frequency AC drive.
Yeah looks like you may have to buy a 0.5 horsepower 230V three phase motor if you want to use the PF525. AutomotionDirect has some for around $100.
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
571
Good Evening Everyone, I tried to find pick through the forums and found some similar problems, but could not find quite what I was looking...
5,655
im looking to connect with my laptop by serial port and drive explorer w/ rs1 adapter, i have the adapter and my ab dealer says to use a null...
2,070
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
47
