Cajunman0821
- Join Date
- May 2004
- Posts
- 3
I am new to PID and have a question about the control output.
First of all, I am using a DirectLogic205 PLC with a 250-1 CPU. I have a 4 channel analog input and an 8 point output module.
After setting up the PID the control output goes up if my set point is higher than my process variable and goes down if the SP is lower. This part makes sense to me, sort of.
The problem is that I would expect the CO to be a certain value when SP=PV and always be that same value when SP=PV. But, the CO does not change to the same value, it just stops changing when SP=PV. So I could have a value of 1000, 0, or anything in between for the CO when SP=PV.
How do I know when to turn my outputs ON or OFF?
