What are you using for labeling your control enclosures
ndzied1
Aug 2002
Chicago, Illinois
2,856
What are people using to put their manufacturing tag on industrial control panels that they build for other people?
Do you you an adhesive label or mechanical label?
If a mechanical label, how do you attach it to maintain the enclosure environmental rating?
Usually use adhesive label. Sometimes when requested for fixed mechanical label, I use self tapping screws with a sealant on the screw.
It's less about form and more about function
Paper, Plastic, Metal...Logo, Size... does not matter.
Succinct content DOES matter. There are two overlapping codes in NFPA 70 National Electrical Code which dictates the minimum electrical specifications that SHALL be listed on the marking.
See:
409.110 Industrial Control Panels, Marking
670.3 Industrial Machinery, Machine Nameplate Data
If shipping international, CE and other International codes may apply.
Regards
Plastic
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
54
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
115
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
221
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
59
104
