Ascii interface with A&D balance
PLChristian
May 2021
Wisconsin
27
I am tasked with interfacing an A&D balance and a compact logix L24er with a 1769-ascii card. I would like to just display the weight displayed on the balance in Studio 5000 but I am having trouble programming. Has anyone had experience with a similar situation?
Hello all. I would like to transmit a command to an A&D balance from a L24ER PLC with a 1769-ASCii card I/O. The command I want to send to the...
1,698
Hi everyone. I am trying to interface a balance and a AB compact logix L24ER with a 1769-ASCII card. I am using a rs232 connection between the...
20
6,877
Hello, I have a CompactLogix 5370 controller, and I need to communicate to a Mettler Toledo IND560 via a 1769-ASCII interface module. Does...
1,485
I have an application where I need to put a Sick CLX490 in "Sleep Mode" and put it back into "Run Mode" (Laser On) utilizing the ASCII AWT...
2,277
Hi friends, does anyone know how to clear the buffer of this module? I uses it to interface with a scanner via RS232, but sometimes the scanner...
3,510
