slick_william
Hello everybody!
I have a Studio 5000 project which uses a ControlLogix 5580 (1756-L82e), but do not have that exact PLC model available to test on.
The most recent ControlLogix I could find is a ControlLogix 5570 (1756-L73) which is very similar, at least enough for my testing.
My question is: My project is already developed and ready to test on the ControlLogix 5580 processor, but I don't have one available for testing. When I go into Controller Properties to try to switch processors, Studio only gives me processors from the same family / generation as the original processor in the project (5580), so there is no option to select the 5570 processor. I do not see a way to test my current project on the 5570 processor without exporting it, and developing a sort of one-off application specifically for testing, which is less than optimal. Does anybody know of a way to revert a project for an 5580 / 1756-L82 processor to an earlier family, like the 5570 / 1756-L73 processor?
Ideally I would like to test on the actual processor (CLx 5580), but if that is not possible then I would like to test the actual program on the best processor I have available (CLx 5570). The only solution I see is to build a side project as mentioned, which is less than optimal as it may introduce irregularities / anomalies into the process during migration/development, and as a general rule I always try to test as close to actual real world / typical expected conditions as possible.
Thanks!
Thanks!
