itsgowribe
Hi All,
We are using M580 Level 4 Hot Standby System. We are using the BMENOC0301 module to do Modbus scanning from the Modbus units (Genset Woodward SPU – here after we call it as “SPU Units”) using the DTMs.
We are facing the Intermittent communication in the NOC modules and the SPU Units. We have noticed that whenever we restart the PLC, or the SPU is turned OFF/ON the NOC module is not able read the data from All the blocks in the SPU units.
We are reading around 5 blocks from each SPU units. In Total there are 14 SPU Units. All the SPU Units are going through a switch connected to each other and the HSBY PLCs. We have discovered only after we unplug and plug back the Ethernet Comm cable at the SPU Unit side, then the NOC Module is able to get or read all the data blocks from that SPU Unit.
I have the Architecture for your reference.
We have done the trouble shooting and monitored the Status of the NOC module. Here are few pictures for your reference.
