VFD & Mechanical Brake
Did you purchase a license for CCW ? Mine is the free download, perhaps there is no print unless its licensed. I have every other Rockwell software I am unaware if CCW needs one to have more features. it is a Standard Edition not a lite
mine says CCW developer and looked at factorytalk activation manager and it says CCW developer license.
Maybe use snipping tool to grab the nondefault parameters?
Ill just do a spread sheet. At least I am able to go online with this fee version and
load parameters. My Co. would buy me the license if I asked but I really don't use it and
don't use the 800 series micro controllers. I know you can use it on some of the HMI's but I have FTME if needed. I stay away from AB HMI's if possible. Thanks for the help
I think you can open up the pdf and go to the parameter list. Copy that into a spreadsheet. Then make a non default column. Then after you know what parameters your going to change, just filter for the non default and copy that onto a saved spreadsheet of parameters that are changed.
Only problem is during firmware changes that changes somewhat, but should not change very much.
We are using a Powerflex 70 VFD to drive a Sew Eurodrive motor with a built-in mechanical brake. The brake is powered from the feed to the drive...
8,532
Hi everybody, looking for some advice here. We have a Toshiba molding machine with a rotary platen. Its kind of a prototype machine, there's...
2,151
Customer want to use contactor for their 5HP motor blower application. im leaning to VFD. anyone use contractor for blower application...
146
74
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
134
