plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old January 10th, 2021, 03:30 AM   #1
arbj
India
arbj is offline
Using MODBUS TCP for connecting to Siemens S7-1200 PLC
Hi All,
I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4.
This uses MODBUS TCP for interfacing to host devices. I would like to connect this to Siemens S7-1200 PLC via MODBUS TCP. According to the manufacturer, the S7-1200 PLC can use MODBUS TCP to connect to the motor.
The Siemens S7-1200 PLC in question supports PROFINET, but I am not sure about MODBUS TCP.
My question(s) is
1. Do all S7-1200 PLCs with PROFINET support MODBUS TCP ?
2. Are there any limitations with this type of connection as opposed to PROFINET connection??
3. Is there any tradeoff when using MODBUS TCP??
I could buy a PROFINET interfaced motor, however they seem to be few in number, compared to MODBUS TCP or EtherNet IP. It will be a waste for me if the motor is unusable on a PROFINET device, as most of my customers use EtherNet IP.
nm
Old January 10th, 2021, 04:53 AM   #2
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
Here's the answer to Q1
https://cache.industry.siemens.com/d...s7-1200_en.pdf
__________________
S7-300 to 1500 conversions done - email to s7conversions@hotmail.com
Old January 10th, 2021, 07:22 AM   #3
arbj
India
arbj is offline
Re:
Thanks for the post. I need to create MB_SERVER and MB_CLIENT connections for exchanging data. Is this supported on earlier versions of the S7-1200 CPU?? Unfortunately I do not know which version my customer is using.
thanks
nm
Old January 10th, 2021, 08:18 AM   #4
mk42
United States
mk42 is offline
Quote:
thanks
nm
You can test it in Portal by creating PLCs with different FW versions.
That said, I'm pretty sure it's been supported for a while. Maybe not V1, but it definitely isn't a new feature.
As for tradeoffs and limitations: Modbus TCP is generally slower update (maybe 100's of ms instead of 2 or 4ms), but that's often OK. Modbus TCP comms are defined in software, whereas PN is defined in HW. It definitely works though.
Old January 10th, 2021, 01:08 PM   #5
504bloke
England
504bloke is offline
504bloke's Avatar
Have a read of this siemens modbus document
__________________
Regards
Dave
"When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity."
Albert Einstein (1879-1955)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Modbus TCP messaging with M340 PLC squb LIVE PLC Questions And Answers 3 November 9th, 2020 06:07 PM
Siemens S7 to Modbus TCP boneless LIVE PLC Questions And Answers 11 May 30th, 2017 11:12 AM
about communication between PLC S7 1200 plc and new KTP 400 HMi yhvadar LIVE PLC Questions And Answers 3 August 27th, 2015 08:38 AM
Siemens S7 1200 plc ndrghrdr LIVE PLC Questions And Answers 4 December 9th, 2011 08:56 PM
Mitsubishi Q Series Modbus TCP module QJ71MT91 set up help req'd... Pocko LIVE PLC Questions And Answers 0 July 30th, 2006 03:45 AM
