JCreel
Hello all, i am currently trying to connect a panelview plus 6 to a siemens 505 via kepware.
I have not had alot of experience with kepware and all of the tricks of the trade involving the software, but i have it downloaded to my PC, and have added all the necessarry tags i want into the channel. I also have added the tags to the rockwell project, and if i run a simulation on my pc of the mer file it works perfect because the OPC server is running on my pc.
However when transferred to the actual terminal, it will not connect and display the data. I have already enabled the drivers on the terminal to support the kepserver but i cannot get it to run correctly. Do you have to download the OPC server onto the Panel View?
**NOTE** I am using the free trial of Kepware at the moment, but i would think i should be able to use most of the features.
Any help would be appreciated, i can also provide more information if needed.
