FactoryTalk ME, Global Objects, and Parameter Files
testsubject
Feb 2004
Chicago, Il
839
I am have a hellofa time trying to find an answer to this:
Is it possible to use Global objects with Parameter files?
I see that I can embed parameter lists in the global object and then insert tags in the object after copying it to a screen but I cannot see how to insert a parameter list. This appears to only work if the object is created locally on the screen itself.
I have a project where I am creating around seventy iterations of this object and thought editing Parameter files would be easier than editing the parameters in 70 objects....
I do believe you can use parameter files with global objects, but they have to be set at the global object level. That is, once it's set in your global objects, you cannot change it at the display level without breaking your link to the global object. If using 70+ objects, parameter files is a good idea. I *think* (although I've not tried it personally) you can use parameter files to reference other parameter files, kind of like nesting parameters. Whether that is a good idea or not is up to you. That can be a very slippery slope as it will be difficult to follow should you have to troubleshoot it later.
Jason,
Thanks for responding. That seems to confirm what I am finding. I will need to be able to assign different parameters to each object so I guess I will just use parameter lists at the global level instead and edit them on the screen when inserted.
Hello all, I am working on a project in FactoryTalk SE. Suddenly while working on a new screen, the global objects I am copying to it are not...
1,269
Hello guys, can anyone help me with FactoryTalk View Studio. I need to use a Global Object that contains VBA Macros in different displays, but it...
1,677
I have a FactoryTalk ME application with some global objects for diagnostics of 1769 and 1719 IO modules that don't work. They were developed by...
1,897
Hi all, Does anyone know of a way to pass global objects a parameter file name as a variable? e.g passing {#101} or the like to the to...
1,313
I have a similar question to a previous post but thought it warranted its own thread. I have a global object (primarily acting as a goto display)...
1,556
