Compactlogix to Telesis TMC470 Ethernet communication
kjacoby
Jul 2011
Right Here
91
Good morning. I have been working on integrating a Telesis TMC470 using their #77918 ethernet adapter. I can get a string to send, but it is not in the way Telesis says to do it. I have used 3 different manuals, and they all don't seem to correlate with the way this adapter works.
From Telesis:
"Byte 4 (message type) should be an 86 which represents a V (sending variable text) Your message should start in byte 5 and continue on each byte. You must toggle Byte 3 each time you want to send new data."
So when I send the String "TEST" in the format they say, my string comes in as "VTEST150". If I put a 85 in Data[4], which should be an invalid assignment since V calls out a variable text to the Telesis, my string comes through as "UTEST149".
about a second or two after the string comes through, my variable changes to "?000000095" and stays like that until I toggle byte 3 again. I really think there is something goofy going on with the ethernet adapter, but I am having a terrible time getting responses from Telesis on these issues. I get a quick reply, and don't get any more responses.
I did notice if I change the output values of data[0], data[1], and data [2] the text reflects those numbers. So with a 3 in data[2] the text comes is as ?000003098. Changing Data[2] back to 0 and the string will change back to "?000000095".
I have also noticed that when the ethernet adapter is plugged in, I cannot go through any menus. It constantly kicks me out of the menu.
I am basically wondering if anyone else has experienced these issues with a compactlogix, using their #77918 ethernet adapter.
Thanks,
Ken
Well, I finally got a little somewhere with Telesis. Come to find out the ethernet adapter they sold me is not compatible with the 8 pin head I am using. And there isn't a way to add a gateway address to the ethernet setup.
They are now telling me I need to use TCP/IP, or rs232. But they have no clue what message attributes I need to use.
They said its for my controls department to figure out (me). Starting to think I will just need to get an real time automation ethernet to rs232 gateway and give it a try.
I believe the last time i used a telesis they sold me a 232 to ethernet adapter. And that is what we used.
It looks like an inline adapter.
Ill have to look back at my files.
I am involved in sending as ascii string from the RS232 port of a Compact Logix to a Telesis pin-stamper. If anyone has successfuly done this, any...
7,077
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
95
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
96
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
112
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
473
