TIA Portal HMI Tags
Pele_1968
May 2021
Vancouver
In TIA Portal, Is it possible to have all HMI tags linked automatically to the PLC or do you have to go through each HMI tag individually and link them to the PLC?
Even though the description is identical for each PLC, and HMI tag, the tag is "red".
BTW there is a connection between the PLC and HMI, I have confirmed that already
Not entirely clear what your issue is but if you browse to the HMI tags in your project and right click there's an option to synchronise with the PLC tags. This should get rid of any anomalies.
I think that somehow he has gotten a lot of HMI tags that are no longer syncronized with the PLC program. Maybe he has been copying a lot between projects. Or he had some tags connected to a PLC, and then he deleted the PLC connection. Or something like that.
In WinCC Flexible there is a function to re-syncronize tags. I suspect there is something similar in TIA. Have never had the need for it though.
I don't know.
He can try. Or, if he has tags that are called the same in the HMI and PLC tag table (and same project) he can delete ones in HMI table and paste the ones used in PLC SW.
Or he can use a proxy PLC object to show needed DB's and sort them this way. It would be easier if there are more details.
But I hope your way is the way to go.
Hi guys I after a bit of advice on Tia portal graphics, I would like to add a conveyor belt graphic to a hmi and the conveyor in the basic...
181
hello every one. i'm new to tiaportal, i have created new project and HMI screen the program works fine with PLC-sim, but when i try to cntrol the...
402
My PLC (S7-1200) and HMI (KTP-1200 Basic) has been delivered on-site to the customer. To be able to do "off-line" updates to the code, I am using...
221
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
705
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
564
