Maximum length of cable for stepper motor step pulses?
arbj
May 2011
mrt
61
I have a stepper motor with integrated driver, the driver needs a pulse input signal and direction input (see specs..http://www.anaheimautomation.com/manuals/stepper/L011154%20-%2023MD%20Series%20User%20Manual.pdf)
I estimate the step input signal to be around 5Khz. The design of the system is such that the stepper motor is housed in a separate unit, while the step generation part (achieved by a PLC) is in another housing, both are connected using male and female panel connectors.
My questions are....
1. How long can the step input cable be ??
2. Is it advisable to run a long cable in an industrial environment, which contains several heavy duty motors running in the area ??
3. Is it usual to run long cables for such a task (ie: pulse generation )??
a
IMO base on the manual,
if i not wrong not more than 1 feet
so far i know for stepper motor , no above 1 meter depend of brand.
Hello guys, I have an issue about maximum cable length calculation of a digital input on Siemens SM321 card. by calculation and according to...
2,848
what is the maximum length of cable can modbus rtu go? do you have any curve showing cable distance versus baudrate?
3,608
Hi. I have a plan shown in picture below. I want to know can I use DH+ network without any repeater/optical fiber/...? I've read AB cabling...
7,340
Kindly , in Siemens PCS7 , has anyone seen and solved this problem ? " Maximum length of code area reached (max. 64 Kbytes) "
2,255
Hello, In a profibus DP-DP network which consist of three CPU315-2dp , 1.What is the maximum length of data that can be transferred between the...
3,210
