IO field reading problem (WinCC Flexible)
vojvoda1982
Nov 2010
Belgrade
Dear friends,
I have a problem with IO Field reading in WinCC Flexible 2005 Advanced! This IO field is point to the internal tag current_float, which is REAL type. This tag contain scaled value from external tag current_plc (his address is PIW268, type WORD).
tag: current_plc > events > Change value > Linearscaling:
y = current_float
a = 0.01
x = current_plc
IO Field mode is set to Output! Problem is when a runtime is started, IO field can't display scaled value from PLC address PIW268! It's display 0.00! I can't understand way?!! It seems to me everything is fine! In PLC, value of PIW268 is changing! Why this change isn't displayed on my WinCC Flexible application in IO field?
Other tags I've created, slider control, switch on/off (for writing on PLC) works fine!
You must scaled value from PIW268 in REAL type in PLC. For example if you send 27000 in type WORD, in type REAL it equal to 3.783506e-041...
I'm sorry, I'm not quite understanding you.. Can you explain me what do you mean with the scaling in PLC? I'm using Siemens S7-300 plc.
As I recall, the function used to work with the same data type (real to real). Use FC105 ''SCALE'' from Standart Library / TI-S7 Converting bloks for convert PIW268, type INT to to a REAL value. New value obtained is used in WinCC Flexible.
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
72
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
645
Looking for a LIDAR sensor (2d) that we can use with a Siemens PLC for measurement, Would like to interface directly with 4-20mA or a Field bus...
957
Hi Guys, I am doing a project that involves a Ring Configuration with 1756-EN2TR with Field Fiber Device 1783-ETAP2F and 1783-ETAP1F. I am not...
2,076
For Ethercat field IO-modules, like f.i. EP2308-0001 from Bechkhoff, you always have an Ethercat in connection and an Ethercat out connection, to...
880
