pak_indo
Hi All,
I am having some dramas getting a Wago to hold an IP address. Now, I had three of these to set up today - the first of which took its address after a few tries --> bootp, power on, power off, test and repeat (which is unusual - it usually works first go). I didn't watch the wireshark during the process of configuring the first one as the job only took a few minutes.
Now, the second one simply would not take its address. You can see bootp do its thing (sorry - no screen grab) and similar in wireshark (screen grab attached). After bootp has supposedly assigned it an address it makes a request for 192.168.1.3 and sets itself to that (I am trying to set it to 172.22.23.21 - bootpab file attached).
I tried the third unit and the exact issue occurred.
Now, my hardware for this is laptop --> straight thru cat5 ---> wago. I have also tried going thru a router with no luck.
I have also tried:
* 3 different machines, my own, colleagues and another server on the network. The first two connected point to point with straight thru cat5, the third over the network).
* to use different bootp software (the AB bootp software).
What are my options here? I am really at a loss to explain what is happening. I have used bootp many times in the past and never had issues like this.
Thanks in advance for any advice.
Ron
I have also tried:
Ron
