Hi everyone,
I have a micrologix 1100 which I was working with through the ethernet port. It was working fine untill I programmed it with program I was testing in which I had not set up the ethernet configurations ie no bootp and no ip address.
I programmed through the ethernet port and after programming the ethernet port was disabled as expected. I went online with a serial cable and set up ip configurations but since then the ethernet port does not rsspond. Eveen when I used a croSs cable and connect directly to pc with bootp enabled I cant get a network coonnections.non of the network comes on.
Have I disabled ethernet somehow? Or the port is damaged
