AB Micrologix 1200
benlomond66
Nov 2017
Florida
Howdy folks!
I'm helping a PLC hobbyist put together a project with a mixed bag of used and new equipment, one being the Micrologix 1200. (Used)
I don't have a wiring diagram for the unit. It is a 24 vdc powered unit with mainly 24 vdc inputs mixed with dc and 5 relay outputs. I believe it is of the BWB flavor.
Also, we are in possession of a 1762-1F20F2 analog expansion module with the same problem. No drawings. We are trying to bring in a 4-20 ma signal from an Automation Direct ultrasonic sensor of the UK1A-E2 variety.
Anyone out there know a source for this information?
Google "MicroLogix 1200 user manual". Should be one of the top hits. The wiring diagram is in there. Good luck.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
681
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
515
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
762
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
677
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,285
