Micrologix 1400
ngilbert
Oct 2017
Ohio
28
Hopefully a simple fix but we'll see.
I just received a new MicroLogix 1400 L1766-L32BWAA Series C
In Rslogix500 on the Controller Properties window it does not list a "series C" of this Micrologix, only a Series A and Series B. How do I get the correct series to show up?
The newest is V11, series C I think just came out this year so unless your running a newer version only A and B will be your options.... you can download the newest version if you have a contract with Rockwell
Have you tried B and see if you can go online? it may work
Maybe that the series C is to new?... try using series B, I think its just updating the Ethernet port so it may not even matter, I still have some series B that I need to use up before I start using the C
Series C is new hardware from about June 2017. It is functionally compatible with Series B.
RA Knowledgebase Article 1042323 (access level: Everyone) addresses the compatibility of the Series C hardware, and why there is not a Series C selection in RSLogix 500.
My reading of that article is that you define the controller in your RSLogix 500 project as a Series B controller, and the program should load into the controller with no problem.
Yep, I always select B and everything works. Never understood why they don't make a "C" option to select in RSLogix 500... would certainly help with the confusion!
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
61
121
143
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
263
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
367
