RSLOGIX 5000 - Lead/Lag Pumps AOI
rahulmm7
Jul 2014
India
21
Hello!!
I am trying to create a AOI to perform lead lag pumping operations based on run time.
I do have 8 pumps out of which 6 are duty and 2 are stand by, and it has to alternate lead/lag pumps in order to equalize the runtime .
Can someone help me by providing some ideas on implementing the logic for the same ?
Hey Ken,
1.One of the stand by pump need to be online.
2. Either to equalise the runtime or on every on/off cycle.
3. No, it depends in the demand.In this case it is based on the flow rate.
I have said it before, and I'll say it again....
Balancing the run-hours of a pump set is, in many peoples opinions, not a good idea.
Many pump manufacturers specify maintenance after XXXX hours of running, and if you've balanced those run-hours, you'll make them all come up for maintenance at the same time, putting a strain on your maintenance people.
What I have often done is introduced a deliberate offset by running pump 1 continuously for YYY hours, before bringing pump 2 into the mix. then after another YYY hours, bring pump 3 into the mix, and so on.
You end up with a nice orderly progression of maintenance requirements that will keep the boys happy.
Agreed. Run one pump to death. Only use the other as intended - a backup if the first one is offline.
Greetings! I am currently working on an intuitive AOI to perform lead lag pumping operations based on run time. The concept is to...
7,042
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
78
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
190
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
633
