Compactlogix 1769 L16ER Factory Reset
JuanPLC74
Feb 2017
Houston
23
Hello Everyone.
I'm commissioning a compactlogix 1769 L16ER that fails to bootP to set an IP address, and when I connect it via usb to RSLINX, the USB network popsup for a second and then disappear, so I can't configure it either using that method.
Basically I'm unable to communicate to it at all.
All lights on it are off except the OK light which is flashing red.
Thanks in advance for any help.
Garry, both threads point to L32E or L35E, which had a side cover with a battery. The L16 does not have such a clip-on side cover.
I'll check the L16 later and post back if no one beats me to it.
Hi everyone,
I have a Compact Logix L23e, which is faulted (OK indicator fleshes red), and Software rev 1.016. I could not make firmware upgrade because of fault status. Any help how to solve this issue please?
Also: what is the right procedure to do a factory reset?
Hi everybody, I have an issue with the realtime clock on the AB 1769-L16ER-1BB1B. Every time I cycle the power the time reverts to Jan 1, 1998 at...
17
6,049
I plan on using a CompactLogix 1769-L16ER-BB1B , to control 3) PowerFlex 40 with a 22-COMM-E communication card in them. I took notice that in the...
22
18,042
I'm still very much a novice, so if you're kind enough to offer help, bear it in mind and take nothing for granted! I've just powered-up a brand...
3,925
I'm sorry to bother you guys. I am new to this 1769-L16ER-BB1B , all I need to do is add a 4 Input Analog Module to it. I am looking at purchasing...
1,203
I have a customer trying to communicate with a CompactLogix 1769-L16ER using TAG READ and TAG WRITE commands. We connect with the node - but...
4,972
