EvoLabels Labeler ( Flexwipe ) - Interfacing with ControlLogix
Aug 2016
Virginia
343
Good Afternoon ,
Thinking of replacing a Labeler with a brand , named EvoLabels ( Flexwipe ).
Sounds like their communication is using Modbus TCP . I know that ProSoft would be an option . Is there any other methods that you would recommend ?
From Evolabel's manual ......
"Evolabel printers provide a Modbus TCP interface which can be accessed on the standard Modbus TCP port 502. "
Thanks so much ,
Depending on ControlLogix Ethernet module, you may be able to use Modbus TCP Client AOI that is available in the Sample code library.
I'm having an issue getting an Ecoline 100-XS label dispensing machine connected to my PLC. The interface cable is a 15 pin Sub-D connector. I...
709
cant think of a way to track bad labels .Anybody have any ideas
5,115
Good Morning , We are looking at getting a Evolabel Flexwipe Label Maker . Have any of you have been involved in using these ...
2,357
