GE Fanuc 90-30 CPU350
BabyLuda
Jul 2021
Arizona
Hello everyone. I have a one off machine that uses a GE Fanuc 90-30 part number IC693CPU350-CE. The only software I have for my computer is Proficy Machine Edition 7.0. I'm trying to do an upload and get a copy of the program printed to help with troubleshooting and eventually convert to a micrologix. The vendor has been less than helpful, and a colleague says they password protected the PLC. This is unverified though. (I don't even see a spot to type a password into) I have cable IC690USB901. I have no other knowledge about what software was used to download to the PLC or anything else.
My issue.. I get the software open and select my series 90-30 PLC. Get the com port set up on the target and then hit go online. It just keeps trying and trying. The retry count keeps incrementing up. Once I click go online, I see the PS Port flashing green as if it is communicating. If I change the baud rate or the parity and try to go online the PS Port will not blink. Any ideas on what to try next? I've searched all over and have had no luck.
I'm not sure how I missed the original post two years ago. The occasional flashing of the LED indicates traffic on the serial line and probably represents the attempt by PME to establish a connection. That's a good sign because it shows that the Windows has set up the USB/serial converter at the same COM port number as PME is using. The original programmer may have changed the port parameters in the PLC from their default settings.
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
48
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
82
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
86
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
148
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
170
