Allen Bradley SLC503 Communications
rick2517
Aug 2005
Kentucky
I have an Allen Bradley SLC503 processor. I want to set up communication to it from the COMM port of my desktop computer. I don't have any cables yet. I will have to purchase the proper cable. The SLC503 processor has a RS-232 port and a DS485 port. Which port would be the preferred port to use for my purpose. Thanks
1747-CP3 will connect PC with serial port to 5/03
Also you can use any null modem cable or make your own:
2-3, 3-2, 5-5
RS232 CH0 is the port you want
DH485 will require 1747-PIC or 1747-UIC
If all you want to purchase is a cable then use the RS232 serial port. Additional hardware (and additional expense) will be requried to communicate via the DH485 port. Any standard RS-232 modem cable (not extension cable) will work. The pinout of such a cable for DB-9 connectors is
2<---->3
3<---->2
5<---->5
You can make your own if you want to.
You will also require RSLinx software to communicate with it.
If you want to program the SLC5/03 you will also need RSLogix-500.
Any application that communicates with the PLC must either "speak" DF-1 protocol or use the RSLinx DDE or OPC drivers.
If you want to network to two or more PLCs you will have to use the DH-485 port and will need the extra hardware - since I dont think that is what you are asking, I won't go there.
The A-B cable you would need to use is a 1747-CP3 (A-B list price $72.00). Or you can also use a standard RS-232 serial cable and null-modem (and possibly a gender changer) from a local source like Radio Shack.
You would use the RS-232 (9-Pin, D-Sub) port on the SLC-503, But you do need RSLinx/(lite) for a driver and RSLogix500 for programming/viewing purposes.
If your computer is new and doesn't have a built-in serial port you may also need a USB-Serial adapter (the one at Radio Shack that I purchased seems to work for everything I have except for the 1747-PIC).
If you want to go thru the DH-485 port you will need the above-mentioned PIC or a 1747-PCMK card and cable. But these last two options can get quite pricey and the PIC requires a built in RS-232 port on your computer.
The PIC is not compatible with USB-serial adaptors.
The PIC adhered rigidly to IEEE standards for RS-232, something that computers have not as voltages have dropped for laptops and cooler running CPUs.
You can get the 1747-UIC which is a PIC replacer - a USB to DH485 converter. IIRC, It costs about $300.
When using a USB-serial adaptor on a laptop I recommend you open Control Panel -> System -> Hardware -> Device Manager -> Universal Serial Buss Controllers -> Right click on each of the root hubs -> properties -> Power Management -> Uncheck "allow computer to turn off this device to save power" Because if your computer turns it off you will have difficulty re-establishing communications.
Thanks very much for your answer regarding communicating with my SLC503 processor. I am using the port you suggested and a 1747CP3 cable. I am purchasing RS Logix for my programming. Am I correct in understanding that I will need to have RS Linx(lite) also? If so, I have available RS Linx software which is several years old. Would it be possible for me to use this or would I need to purchase an updated version of RS Linx?
Thanks so much for your help. RICK ( [email protected] )
RSLinx Lite is free. It will come with RSLogix 500 or you can download latest version from AB.com
hi booten
can u provide me the details about the allen bradley based plc system.
i am new to this and i want ot learn the AB plc and rs logix 5000.
bye
swathik.
What Is Diffrenent Between Dh 485 Rs484
Dear sir,
I have RS232 converter to RS485, is it possible to use for communication to SLC500/1? what is different beetwen RS485 and DH485. Thank your for your help
regard
definal
Yuo need the 1747-UIC cable to use the 500/1 DH+ channel standard rs 485 converters do not handle DH+ handshaking correctly. The main differents between RS 485 and DH+ is the type of handshaking and protocals
Slc500/01 Communication
Thank you for your information. Mr Modred,i have read on the manual SLC500/01 That communication just "received only" i'm just thinking this porcessor can not handle DDE using such as MS Excel or another software.If this information is true so i can not use the processor and replace by slc500/03 minimum and very expensive for me.
thank you
Hello, Please , I need help, I want to configure a DeviceNet network. Indeed , my DeviceNet network consists of : 1747 SDN Allen Bradley...
4,780
373
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
94
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
682
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
446
