Three Pump alternating program for RSLOGIX 500
Carlos V
Jun 2007
George Town
17
I work at the local water utility. We have a pump house with three pumps. The current slc500 RSLOGIX 500 program is set up for a duty pump and standby pump alternating system. This is how it works. Under normal conditions one pump (the duty pump)is running. If the pressure drops below a preset value for fifteen minutes the standby pumps comes on. Once the the pressure rises then the duty pump turns of and then the standby pump becomes the duty pump. The problem is that demand has increased so much that it is now necessary to have a second standby pump come on when two pumps are already running and the pressure is still low. I have an idea on how to do it but I am unsure how to write the programming for the alternating between duty pump to standby 1 pump to standby 2 pump. I figure if I could get a copy of a three pump alternating program it would help me a great deal. Help anyone.
Hello Guys, I have tried the programming but can't twist my mind to make it work correctly. I'm using S71200 and TIA Portal. My system has...
208
Kindly, we connected electrical power, 3x380 vac, between a supply station and an electric cabinet, away 180 meters. The calculation software...
854
im new at Allen bradley rslogix programming; i have something to ask you guys , and i will be happy to get answers so thank you in advance. when...
594
Hi all, We had three drives fail upon power up. The two had F081 fault code. The maintenance personnel attempted to copy VFD parameters using a...
1,551
Monday, we had a VFD that controls the spped of a conveyor belt fail on us. Took the replacement out of the box, installed it and bam, it failed...
37
16,885
