SLC 5/02 connection with laptop
From memory the 5/02 is DH485 and not ethernet
You may have blown something up!!
You need an AB PIC (USB or Serial one) or a PCMK card with the correct cable.
Does the 5/02 not have a 9 pin serial port ?
this RJ45 is NOT Ethernet, it is DH485
This RJ45 has 24V on some pins and will demage laptop if connected to Ethernet port
The only way to connect is to use 1747-PIC or 1747-UIC
To add to this, see below
Thank You so much for the help, I have connected before but I have slept since then and didn't remember how I did it. For some reason I was thinking I plugged directly from computer to SLC ??
Thanks again,
Canyon
Thanks again,
Canyon
If you plugged the SLC5/02 port directly into your computers ethernet port then check the ethernet port, the SLC's port has 24VDC on it. You may have damaged your computers ethernet port.
Hello all! I have some machines that run an SLC 5/03 and occasionally a fault is generated. Recent Example: A power supply wasn't screwed in...
424
OKAYEverybody I need some of your help and guidance again. I have a piece of equipmentbuilt around 1975, let's call it a printing press to...
22
5,476
Hello all, I’m having a difficult time trying to achieve a DH485 connection between an AB PLC with CPU: SLC 5/03 to DOS 6.22 Shell...
2,859
Customer has a SLC 5/03 with some custom HMI with its own IO driver. When the HMI is running, i cannot use RSLogix 500 as the Serial Port is...
1,836
I have an old slc 5/05 I am trying to setup on ethernet and I cannot see it in links... I have the following equipment: PC = windows XP Slc -...
1,935
