RSLogix5000. Open Trend Log in Excel.
smcmanus
Jan 2006
Vancouver
109
I am able to save a recorded trend to a log file. This file has an extention "TBS". For example "mytrend.tbs". Now I want to be able to open it in Excel and maybe view it in a chart. Does anyone know if this is possible? Thanks for your response.
I believe you can save it as a .csv file as well. Then you'll be able to open it.
I confirm Paully's5.0 post - choos CSV file as your trend log save, this will open with Excel. These files tend to be very large, recording values of all your pens at the programmed sample rate.
Alternatively if you only want to draw "graphs" of your trends, why not just use a screen capture program and capture the trend picture from RSLogix.
Alternatively you can bypass RSLogix alltogether, Insert an RSLogix TrendX object directly onto an Excel worksheet (or Word, or Powerpoint, etc.)
If you are refering to the log file saved on a VersaviewCE you need the conversion routine DigConverter.exe
There are two log files saved on the VersaView data.log & data.tag, you need both.
Does anyone know a fast way to find which desktops on the network (by IP) have open copies of a communal program on the same network? Our issue...
1,725
Whenever I doube-click a RSLogix 5000 v20.04 .acd file, I see an process popup called Logixdesigner.exe in the task manager but it never opens up...
3,178
Hello, I'm having an issue with creating a socket using a message instruction. I've attempted to copy the data structures from sample programs...
3,815
I don't want to polute other threads where people were asking this question: RSlogix5000 v16+: how to open local PDF manuals in a separate window...
3,104
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
