FT View Studio ME - pass a string not a tag through a parameter file?
Dravik
Jun 2008
New York
1,650
Hello:
I am currently converting an old panelmate application over to a PV+
I have a large number of popup controls that all look/act the same so I used 1 graphic and tried to pass everything in via parameter file. Tags for control come across w/out a hitch but I can't figure out a way to pass the text labels in w/out making a seperate tag for each. Any ideas? I'd love to be able to just type the text into the parameter file as well.
I had the same problem. I used separate tags for each strings but had them local in the HMI software instead of in the PLC (I cannot remember the reason), so the parameter would reference the HMI tag
If I didn't have 150 of these to do I would have done them individually. I guess creating a string tag for each is one option.
Ohh..
Ok if anyone else has to do that I figured out a way.
In your parameter file you can go ahead and type
#1=TextGoesHere
In your indicator or label then use a literal string instead of a tag, but still use #1 as your 'string' and it will pull from the parameter file.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
148
I have just installed version 14 of view studio, and the tag browser is new. I am trying to assign "Diff_Tryk_saver_1" to a numeric display, as I...
166
Trying to open View Studio and get a message "View Studio was NOT successfully personalized" Anyone ever run into this?
202
Question for those who are in the know how Studio 5000 works/compiles under the hood. The laptop that was supplied to me is now full with no...
580
Hello Experts, I am trying to create a SINE Wave generator and i cannot seem to make it smoother. I have done this before but i forgot the exact...
310
