RSLogix 5000 Hex to string
Are your trying to produce the hexadecimal representation of a number as a string rather than the decimal representation which the DTOS instruction will give?
If don't have RSLogix500 with me but this general method should work
Temp is a Sint
Temp = Sint AND xf0
Temp = Temp / 16
Temp = Temp + 48
If Temp > 57 then Temp = Temp + 7
String.Data[0] = Temp
Temp = Sint AND x0f
Temp = Temp + 48
String.Data[1] = Temp
String.Len = 2
Hello i have been trying to figure out a good way to take hex and convert it to an array of SINT[]. Here is what my failed attempt looks like.
1,306
I am trying to concatenate 3 hex numbers into 1, and I am doing this as follows: 3 registers with 8 bit values in them need to be joined into 1...
3,694
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
94
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
200
