Automation Direct Analog CLICK plc
JonHopper
Feb 2010
Ontario
39
Has anyone had any experience with the new analog CLICK PLC from Automation Direct ?
The application I need it for only requires one analog input, and 10 digital in/ and out (which I can cover with the digital i/o modules).
I am merely wondering if anyone has had any experience with the new Analog input with regards to the CLICK progamming software, and if they encountered any issues.
I am trying to decide between the DL06 and the CLICK Analog.
Thank you,
Here is a question you did not ask. Will you be needing a high speed counter? In your last thread your project bordered on motion control.(Backing off the screw a couple of turns).
Not exactly sure yet if we're going to need a high speed counter or not. Haven't quite decided... an encoder would be nice but not quite sure if it's going to be feasible, and/or completely necessary.
On the Click for high speed counting investigate the use of the interrupt capability on the first couple of inputs. They have 5 microsecond response.
For the first two DC inputs:
Rising and Falling edge :
X1-2: Typ 5 μs Max 20 μs*
W/ a 32 PPR encoder @ 1000rpm this will be more than sufficient as I would need at least 1.876mS. However typical scan times are 1 to 2 ms so theres no way of telling for sure... I don't believe there are any interrupt features for the first two DC inputs though.
I'll probably end up using something like 1 or 2 PPR , in which case it should work fine.
Program tab - Interrupt program - right click for 'Add New Interrupt Program' - create interrupt handling routine.
Function tab - CPU built in I/O Setup - Input tab - Choose 'Interrupt for X1.
Function tab - Interrupt Setup - External Interrupt section - choose added interrupt program to service X1 as interrupt.
I am now learning Automation direct PLC's. Starting simple, using the DL06 and associated manuals,I tried the analog Input F0-04AD1 (intelligent...
1,175
WE HAVE HAD A DIRECT LOGIC 205- DL250-1 PLC FOR 8 YEARS. NO PROBLEMS. LAST WEEK WE HAD A SHUTDOWN AND AFTER WE TURNED POWER BACK ON WE HAVE...
2,003
Hi, I just started working with automation Direct PS 550 and its software productivity Suite. I need to read some analog inputs but I dont know...
2,109
AUTOMATION DIRECT ANALOG CARD need to find out how to access status bits on analog card F4-08THM-J. Should have short circuit and burn out...
3,121
This is a problem that recently arrived on a working machine. I am getting a constant 4095 (12 bit res)in my plc register from my analog card. I...
4,226
