Loop Script In WonderWare
chrisj91
Nov 2010
England
33
Okay, I know I've posted a few questions about WonderWare recently, but I'm still in the learning process . . . !!
So, I have a script which plays a Windows sound when an alarm is active, only problem is, it only plays it once and then doesn't continue playing it . . .
I'm thinking I need to keep looping the script so it keeps playing it until it becomes a '0', but am unsure how to go about this . . .
Could anyone point me in the right direction . . . ??
Use a condition script and a "While True" action.
Data Change scripts fire every time the data changes. Condition scripts can execute under any or all of these conditions: On True, On False, While True (timer repeatable), and While False (timer repeatable).
Wonderware is soooooo much nicer then FTView.
Thanks for a speedy response rdrast . . . !!
Exactly what I was after, it seems so simple once you know what to do, I feel like šŸ™ƒ
>>>>Wonderware is soooooo much nicer then FTView.<<<<
Do you think . . . ?? You'll probably hate me then for this, but I actually prefer FTView, I guess it's what you get used to . . .
Thanks again
Thanks again
I'm stuck with View, but it is so broken and clumsy compared to, well, almost anything. I'd switch places with you in a heartbeat.
Please do lol . . . I'm too used to FTView's setup and Wonderware's isn't bad, but it's just soooo different in comparison.
I know RSView wasn't too great, but I haven't really had any problems with my FTView . . . ?? Unless I'm just really lucky ;)
This would also work:
Continious play:
If AlarmDing==1 Then
PlaySound("C:\Windows\Media\Ding.wav",9);
ENDIF;
Reset:
If AlarmDing==0 Then
PlaySound("C:\Windows\Media\Ding.wav",0);
ENDIF;
Thanks for the suggestion NFischer1978 . . .
I have already just used the original and coded an alarm silence button in the PLC . . .
Thanks though, always good to know and learn other ways :) . . .
Hi! I have no experience at all with VB script but I think I might need something here. The issue is that we mainly have the WinCC Flexible to...
7,375
Is there a way to pause a while loop for 1 second in Vijeo designer script?
3,733
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
391
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
297
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
289
