input output card misplaced
gaannesh
Jan 2007
25
I have been called for an injection molding machine service.
i am not a plc expert. i found their supervisor misplaced the input and output cards and connected the input wires to the output card .
output wire to the input cards.
Now the problem is output line fuse blows when i give power to output card.
what will be the problem.?
Is I/O card need repairing?
Though it probably doesn't matter now, I would have immediately replaced both cards as suspect. How much does a further malfunctioning injection molding machine cost (including continued down time) compared to the cost of the two cards?
Retain the old input card, label it as suspect, and try it in a non-critical function later.
You should also consider whether any damage could have been caused to field devices (particularly inputs from solid-state sensors), when potentially hit by output card voltages...
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
355
Greetings, I have been charged with a project to link data from a Beckhoff PLC using Allen Bradley Point IO to a PLC 5. The PLC5 does not have...
4,028
Hi, I'd like to tidy up some of our input/output modules legend cards. Over the years some of them have become a bit of a mess where people have...
1,820
How can I use 1 button and 1 light using only b3
266
Hi i would like to ask! Im using Omron CP1E PLC May i know how to use one input to trigger two outputs alternatively? Meaning press X0 on, Y0...
401
