mitsubishi got 1100
weldobot
Apr 2013
ta
i'm a student and new to the world of HMI. i'm trying to connect a PLC with RS232 to Mitsubishi Got 1100. i'm using microcomputer connection of the GOT.
how do i send a string from the GOT?? i looked in the user manuals but haven't found anything that helps me.
thanx,
johnnie
Hi
First of all welcome
I am sorry but I don't understand your question. You are trying to connect to the plc . Could you post what software and cable you are using. If you could post a link the manual you are using then someone may be able to help you.
Could you also post the model number of the plc I.e fx, q series etc
Donnchadh
thanx.
i'm new at this so i'll try to explain what i want to do :
i'm using a non familiar PLC who i program with basic language. my goal is to make a remote control with the Mitsubishi GOT. i'm using Mitsubishi Got model : GT1155HS-QSBD
my problem is that i dont understand the communication method of the GOT. the GOT have a spacial protocol to unknown PLC's called microcontroller. i know how to read and write throw the serial port of the PLC but i dont know what i need to send to the GOT in order receive information from it.
as i understand i need to send a read request in order to get information.
this is the got connection manual (MICROCOMPUTER CONNECTION (SERIAL)):
https://my.mitsubishi-automation.co...871.pdf?id=7016&saveAs=0&form_submit=View+now
i want to use the regular C1 frame (format 3 on the "message format").
can u explain to me how to get start with it?
thank you,
johnnie
Hi friend ,
well i m here with you not to reply to ur forums but im here for your support basically im using for the first time mitsubishi GOT1275 VNBA and im very new to create develop screens like swiches , push buttons , alarms , up and down arrow keys , pop screens etc Brother i kindly request you if you have any material from where i can start please help me i have done HMI but not for Mitsubishi this is first time to me .Hope fully if youcan provide me how to start up with ill b very thankful to you.
Waiting for your response.
Sam patrico
Got hmi
Hi friend ,
Sam patrico
thanx,
johnnie
Hi friend ,
Sam patrico
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
506
Hello, I have a GOT 2000 that is dead and only have a GOT 1000 spare at the moment. I have converted projects up from 1000 to 2000 before, but...
794
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,313
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,390
Good day all We had a GOT1020 HMI installed but has failed recently. We then Bought a GOT2103-PMBD. I need to download our old software to this...
1,418
