I want to connect few PL1504 sensors to BNI006A and read the pressure from the sensors.
In another setup, I have the BNI00AJ as the salve module and the pressure sensors on it, then I read the data directly after using 2 AOIs ( for 006A and 00AJ )
but for the current setup as there are only 3 sensors, I don't want to use any extra slave module and use the existing free ports on the BNI006A (there is no other salve connected to this module).
the problem is that I can't see any tag that has analog value in it, even after having 006A AOI for this module.
