Can't change gateway address of 1756-ENBT
Dave I
Sep 2024
England
I need to change the gateway on a 1756-ENBT because I have installed a NATR on the production line. I have attempted to do it using all 3 of the methods that I know
From RSLogix ENBT properties in the I/O configuration
From RSLinx classic
Using BootP / DHCP tool
No matter which method I use, when I go back into the settings it is still set to 0.0.0.0
I have just put a new ENBT into a spare chassis on the bench, set up the IP, Subnet and Gateway using RSLinx classic and it it worked perfectly. However, I took it out to the machine and swapped it with the problematic one and the gateway instantly went back to 0.0.0.0. It's almost as if the PLC is changing it back. Any ideas?
PLC - 1756-L72 V19
Ethernet - 1756-ENBT V6.002
IP - 10.0.0.203
Subnet - 255.255.0.0
Gateway - 10.0.0.25
Hello, I'm looking for the installation file of INAT.net parameter setting software to configure EchoChange gateway. Unfortunately the www.inat.de...
1,669
Hello, is there any way how to change Gateway of CompacLogix controller without RsLogix 5000 or RsLinx? I need to go online with costumer PLC...
3,826
I have someone out in the field and need him to change the gateway of a micrologix 1400. It currently has the correct ip but needs a gateway which...
1,943
Hello! I am working on a portion of my program to save job data. I have a button that is labelled "Start Job" and this also starts the data logger...
216
Hello to all, I'm trying to generate a code in a Studio 5000 (Ladder) to generate an alarm to detect when the level is not descending as...
175
