Elevator Simulator
struggling but am here know to move the jmpsubroutines to the first page or page 2 also have latched and unlatched bit control for floors, wornvator button outputs activated. limit switch settings set. car stops in between floors. door opens for five seconds and closes.
I suggest you integrate a simulator into the PLC code, that will keep track of the location (I:5) and any proximity sensors (doors are closed; doors are open; etc.) based on the outputs.
  • If the elevator is moving up, increase the value in I:5 by 1 every scan cycle (or every 0.1s)
  • If the elevator is moving down, decrease the value in I:5 by 1 every scan cycle (or every 0.1s)
  • if the door is opening, increase the door-open position by 1 every scan cycle (or every 0.1s), but do not increase to more than 20
  • if the door is closing, decrease the door-open position by 1 every scan cycle (or every 0.1s), but do not decrease to less than 0
  • if the door-open position is 20, then write a value of 1 to the door-is-open input bit, else write a value of 0
  • if the door-open position is 0, the write a value of 1 to the door-is-closed input bit, else write a value of 0
That should be enough to test your code.
M
Hi, guys I wonder if anyone of you have a ladder diagram for elevator simulator in logixpro. I'm student and just stat to learn abou PLC. I...
22,414
Hi, I am working on a project in codesys using only ladder logic and SFC. Now the elevator can go to different floors, doesn't go without doors...
313
Hi, I’m not familiar with servo motion control yet, so please let me ask advice. I am currently designing an architecture for a material handling...
480
when the elevator is at level 1 and someone gets in and wants to go to floor 2 he presses the button and the door closes and should then check to...
282
Hey guys , I have included a couple attachments here , one of what I was supposed to come up with a program and the program I came up with. Does...
3,818
