Flex I/O DeviceNet to EthernetIp
Nov 2023
Detroit, MI
Hello,
I am looking for some information on converting a Flex IO (1794-ADN) which is device net to an Ethernet/Ip Flex IO module like an AENT.
Has anyone done this before or has some information on the process of doing this?
It's easy enough to do. Just remember you should delete it from the DeviceNet scanner so it doesn't waste time trying to scan it.
Then just search and replace the DeviceNet addresses with the new Ethernet addresses.
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
324
Something i ran into that has me stumped, hopefully someone can explain. I have powerflex 70's connected to a L7 cpu using a 1788-en2dn. The...
1,554
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,455
Hi all I am working on a retrofit project. There is one backup pump with Powerflex 753 drive controlled by 2 different PLCs(one 1756-L63 ,one...
1,839
I'm having a strange issue where the operator can input a desired speed in 0-110%, and the scaling will correctly translate that in Hertz to the...
2,699
