FTView ME Global Object Connections Question
Ryan_Flowers
Feb 2019
Las Vegas
70
Hello,
I have never created an HMI project using Global Objects before in FTView ME, so please forgive me if this is ignorant. I need to modify the read-write values a Global Object is connected to, but it is not singular tag based so they reference #'s. I do not know where to find what tags these #'s are connected to. Can someone point me to them if you've experienced this before please?
See attachment if my explanation was confusing.
Thank you,
Hi Ryan
The global object are usaly copied on to other screens and used mulitiple times, the #101 is a placeholder that when you paste the object on to anther screen will be replaced by a tag to point at the control device. I think this is talked about in the manual viewme-um004_-en-e in chapter 25 about page 374
Thanks Nick
I see now; I was not paying attention to the Global Parameter part. You assign them these # place holders and in the reference object on any one display when you right click it you can select Global Object Parameter Values to see what tags are used in them individually.
Thank you for pointing me in the right direction!
this was also discussed here
james
Step 1: Right click your global object and you'll see an option to define parameters for the global object.
Step 2: After you copy/paste the global object onto a display, right click the object and you'll see an option to set parameter values. You'll see the description of parameters you created in Step 1. Then feed your tags into these parameters.
This process is a whole lot easier if your PLC has a UDT or AOI, because then you can feed your global object a single UDT or AOI base tag and then reference the extensions when you create the global object.
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
690
Hi, all! Could anybody please explain why would a global object have the visibility option, yet it's instance will have the visibility grayed...
1,996
Does anyone know of a way to create a global object in FTView SE that would allow me to configure some static text in the instances that can be...
2,511
Hi, I have come across a Global Object using the following string for animation: {/#1::[#2]#3.XX} I think this is being used to make populating...
3,455
Hi, I'm working with Factory Talk Studio and VBA coding. So far, I have two questions. If someone could help me I would be really glad. First, I...
18,434
