looking for hmi recommendations
What do you want to do with the HMI? Do you require historical data logging?
If all you need is an operator panel, the stand-alone units like Maple Systems, Red Lion, or Automation Direct C-More are sold as a separate entity rather than on the basis of the number of tags. HMI software that runs on a Windows machine is typically tag count-based.
If it is windows based as a requirement and does not need a robust historian, then I would recommend Ignition.
Huh? Ignition is probably one of the strongest and most robust historians. Much better than Aveva or FactoryTalk. Ignition is way overkill for a single HMI requirement. Maybe you're thinking Edge?
Not sure what ignition historian you have used, but the last time I performance tested their historian was back on 8.1, and it had major issues pulling large amounts of data. I had to build my own postgres historian using timescale and build a SQL interface to replicate how ignition was accessing the database. FactoryTalk historian is just PI, and is by far one of the most superior historians in terms of performance and data storage. AVEVA historian is very good. Canary is also good for high speed data.
Odd...ive experienced no such issues on multiple factory rollouts integrated together for local visualization to cross division MES. In that Ignition allows for you to roll your own underlying db architecture, perhaps there was a deficiency in your setup not restricted by Ignition. We use standalone MSSQL boxes, querying 30,000 tags A second with no issues.
I can appreciate FT, Aveva and Canary from a time server historian perspective for recording data, however, I've always found their integration beyond the data clumsy and lacking. FT is overpriced, Aveva has one foot in the grave, and Canary isn't an integrated platform.
If you're looking for an embedded (not PC based) machine HMI panel, I don't think I've seen any that do tag based licensing, although most do have a system limit.
Ah, all the ignition work I've done is in systems that are 150k tags minimum. Usually in terms of 250k to 500k tags.
Ignition runs great on embedded computers as a standalone HMI and I think there is a free tier for such installs now, but I don't remember the details.
the 30K was the query size/second. If you're querying 500K tags a second, I'd like to see that application. The overall tag count well exceeds 200K, but if you're having to store and retrieve 200K tags every second, you have Ignition scan classes set up wrong or deadbands set wrong.
Hello, Does anybody know of any good sources to find a new or used working Cutler Hammer PanelMate 1000 8PG (P/N 92-01683-01) Our unit stopped...
90
looking for Panasonic GVWIN HMI programming software... if anyone has something this ancient... please let me know - much appreciated
332
Hi all, first post and all that jazz, This may not be the right place, and if anyone has a suggestion of a better place to post this request...
811
Hi there. In the past I have read many posts about Advanced HMI in forum. I have a potential project for which Advanced HMI could be used, but...
26
14,214
Hi, I am struggling with an assignment and I’m wondering would anyone have a solution to this project for me? Your help would be greatly...
1,986
