PAC Machine Edition Alarm Window - what trigger clear all??
AlexTuzi
May 2024
Brazil
Hello everyody,
So, I am working in this projetc that was abandoned by the integrator. It a PAC Machine Edition PLC and HMI with LV7000 GE drives.
I have a screen where I have an Alarm Window which is set up to show all inverter faults. The problem is that somethin is triggering a Clear All command and all alarms is vanishing when main power is disconeected, even tough PLC and HMI are still on because they are on a no break circuit.
This is quite annoying, because the LOTO procedure here is on the main power disconnector.
Can anyone shed a light?
thanks.
I don't know the PLC, but I can think of a few different things I might try:
1. Check if HMI has an alarm history screen, instead of just active alarms--the alarms should then able to be viewed with a timestamp upon re-energizing power
2. Use a historian like ignition and historize the alarm tags
3. Add a latch or counter to each rung after the alarm output (in the PLC) to "catch" which alarms came in. Depending on the PLC, these should "remember" their last status before power was shut off.
4. Put your 24vdc power supply on the top side of the disconnect, thus preventing loss of power to your PLC and HMI. I personally hate losing my 24v when the main disconnect is cycled.
I'm assuming the HMI is a target in the Machine Edition project and that the faults are defined in the HMI target. There could be a script triggered by something that happens when the main power is disconnected. There will be a list of scripts in the project navigator, but there could also be screen-based scripts. Expand the alarm screen in the project navigator to see if there are screen scripts.
First time posting but can't find anything online related to my issue. I have to change the IP address of the target PLC in a Quick Panel Plus...
170
Has anyone heard of a simulator for Emerson PLCs? Something like a virtual controller for 90-30, RX3i, or VersaMax? Thank you.
283
Anyone ever run into this? It doesnt result in an error on the program but you cannot open viewruntime due to it. A problem was encountered...
629
Hi, I am looking to be able to view different parts of the plant on 2 monitors. Doing some research has led me to Windows PC Mirror Target. I...
353
So I am having to relabel all the data points in a program. I have never used This software before but I am having to reverse engineer the program...
399
