PLC Hardware
ajay2592
Jul 2024
Ontario
Which one is the best PLC to Control a 3-phase induction AC motor?
the sequence of the motor is
1st motor will start after 5 seconds of pressing the start button
2nd motor will begin after 20 seconds of the 1st motor
3rd motor will begin after 20 seconds of the 2nd motor
Any PLC is capable of doing the simple sequencing. The larger question is how are you turning on the motors? With standard contactors? With a Drive? With a networkable device? Beyond that, what's the plans for expansion? If all you anticipate doing is these motors, then any small brick PLC with integrated I/O would be sufficient. PLC Direct comes to mind.
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
259
I've ready through the the previous posts, and we've worked with safety design for a long time. In the past, we worked with Pilz directly, and...
1,098
Hello, Here i have a Tia Portal V11 Project that i wanted to fix but i cant take the device configurations from the device. So i just have to...
1,636
I have next-to-no experience with PLC programming. I am a C programmer, and have an application (in C) running on control PC which needs to get...
40
13,600
I'm sure it's been asked many times but where is the best place to sell, mostly brand new, PLC equipment? Sorry if it's asked a lot. I'm new to...
3,157
