powerflex 755 fault 926
Cld0033
Jan 2025
Alabama
Has anyone had any luck resolving issues with the power flex 755 faulting with the 926-fault code. I have read that switching to revision 14.0 has helped, but my boss unfortunately does not want us to do that. One of our two drives are faulting every hour on the hour.
That's your best option. It's what Rockwell recommends. There is a bug in ver 16 fw. Knowledge base says to downflas to 14.005
We called Rockwell about this several months ago before they had started recommending downflashing. They said it's caused by "excessive network traffic." Well we ended up wasting a bunch of time diagnosing with Wireshark and disabling various network comms, only to find that it didn't help. In the end Rockwell told us to buy their non-embedded ethernet card for Powerflex 750-series drives to fix the issue. I suggested flashing down to version 14 and they said "yeah that might work." Lo and behold, it sure did. No purchase necessary.
So as I see it you've only got two options: buy a new card (~$500) and wait for it to arrive, or downflash, which takes about 15-30 minutes.
Why is your boss so resistant to it? Can he point to any benefit that version 16 gives over version 14?
FYI, I just had an install of 18 PF755s with the external ethernet modules. Same exact problem until I downflashed to 14.
I'll add to this. Same issue in a panel with an isolated switch, a drive, an HMI, and a PLC. Got this fault when we replaced drive. New drive had v16. Great people on here suggested downflashing to 14, problem solved. Actually had to do this to two other drives. The fact that Rockwell hasn't released a v16.1 or something to resolve this is insane... but typical.
They in fact just announced mature active status for 755s with no additional fw releases.
Hello, I will randomly get the 13035-Net Idle Fault when I hook up my laptop to the network that this drive is on. Yesterday, I was online with...
174
We have a Powerflex 755 that we are using for motion. We are getting a Fault on the drive every couple of hours. The faults are : Control Sync...
219
Hello, guys I am having an issue with Pflex 755, when it is stopping the motor, it is going on fault 9 " Transistor Over Temp". Has anyone dealt...
1,696
Hi all - - Looking for advice on what to look for hopefully, I am not a drive guy. Off site today and don't have anything in front of me, but...
6,773
Dear All, please i need urgent help for my powerflex 755 110kw, F13 ground fault . as it occurs in 2-3 times in day and after resetting its OK...
10,003
