SCADAPack 334 - Can't Connect My Device via USB
Mitzurin
Nov 2024
TX
I've been trying to connect using Telepace, and when I connect via Modbus/USB with different printer cables, I get an error message saying, "The send command operation failed. The USB connection is in use by another application." When I connect via Ethernet, everything works fine, and the USB port on my computer functions correctly with other devices. My operating system is Windows 11.
Any help would be really appreciated—thanks!
I've been researching this issue for a while and haven't found any solution that works so far. I'm starting to believe it might be a compatibility problem with Windows 11.
I've been researching this issue for a while and haven't found any solution that works so far. I'm starting to believe it might be a compatibility problem with Windows 11. I've tried different solutions, but none have worked.
You might try posting here...
Hi! I've got a customer that has several SCADApacks at remote sites and I need to make changes in their cellular network system. I have the .pia...
2,308
Hi all! I have lots of experience programming AB w/500&5000 and some Schneider PLCs with Unity and SoMachine (and PL7/TwidoSuite but I don't talk...
4,658
just curious if anyone can give me a ballpark for a scadapack P334, waiting on my local rep to drop me a number but my manager wants a rough...
2,219
Hello Experts, I am new to SCADAPack Platform. For one of my projects, I need to read/write from Ethernet ADAM modules and also from one of the...
5,252
Hi People, I have a ScadaPack 330E that has been sitting on a shelf for a few years (previously working), and have recently re-installed...
2,079
