Siemens Networking Question
You actually don't need a Siemens switch at all, and not a managed one either. You know that right?
You could use anything.
Good to know at least when you're testing things.
It should definitely be visible. I tested it, just in case.
Device discovery works if the devices and PG are on the same L2 network segment. This function uses broadcast messages. Hence the direct connection is recommended.
Are you using a VM? if yes, make sure that virtual Ethernet adapter is bridged to the physical Ethernet adapter you are using to connect to switch (no NAT, no host network, etc.).
As long as correct interface is selected in SetPG/PC, discovery should work fine. I keep this setting at <IFNAME>.TCPIP.1
And you don't have to open any project for the discovery to work.
This was where I was going wrong. The system I inherited has 3 network adapters (scared to delete any incase). I was changing one of the adapter settings to suit, however the connected adapter for the session was different. Changed that to bridged and the switch is listed. I am able to also open the Web Browser as well.
Thank you this was really helpful.
Better to ask just incase something is“enabled” only when working in a project file. I’ll be able to progress with the project now.
Someone mentioned it previously in the thread. The only reason I am using it is because we have spares around that are not needed. To try and keep the costs down I am re-using them. Also Ince I started researching them, I wanted to know how they work and how to configure it, rather than walking away.
If I was doing the project at cost, I would have purchased a normal unmanaged switch.
Hi Every one I want to hookup the 10 numbers S7 300 PLC CPU on MPI Network . CPU,s are running on 10 different machines with 12 " HMI on each on...
2,420
Ok then guys, I have a IM151-8 controlling a small stand alone filling/packaging line. When it was delivered it was set with the default...
3,084
I have a couple of 315 2PN/DP processors on the same subnet. I want to use the GET and PUT FBs to pull and push data from PLC to PLC. Can anyone...
1,901
When i start the Siemens PLCSIM with some program uploaded, is it accesible from the network?For example if the hardware configuration have...
4,207
Dear All, I have made a project with 2 plc's (CPU 414-2DP) and 3 PC stations connected with each other in profibus DP. All PC Stations use CP...
3,833
