Hello,
I'm having an issue with response times with analog inputs from a 1769-IF4XOF2 Combo card with a 1769-L30ER PLC. The analog inputs are level sensors(3 submersible pressure transmitters, 1 radar level sensor) coming from a wetwell nearby.
The time to see a change in raw input value is anywhere between 5-30 seconds, which is excessive. The radar sensor which is a VEGA C21, has a bluetooth functionality where i can see the level being reported through some of their software, and the value seems to be changing faster than 5-30 seconds as well.
The RPI of the card is set to 80ms and the program runs on continuous task at around 1ms.
Oddly enough, when we tried disconnecting the sensor wiring from the card and used a multimeter to produce varying 4-20ma signals into the combo card, the change in raw input value was instantaneous.
Does anyone have any idea on what is happening here?
Thanks.
Thanks.
