Omron CJ1W-ETN21 Automatic Address Generation Error
scrambled
Jul 2015
Brisbane
108
I have an Omron CJ1M PLC that does Modbus TCP comms via an CJ1W-ETN21 Ethernet module.
At the moment, I have set the ETN21 to automatically generate its node address from the last octet of the IP address. In my case, my test IP address has 156 as its last octet. So I set the two node address dials to 9C (hex equivalent) on my ETN21 module. Should be fine right?
However, when I do so, I get an ERH flashing LED on the ETN21, indicating an "address disagreement". Modbus TCP comms works fine but I'd like to find out why the ETN21 is giving me this error.
I checked the CIO error word and the "address disagreement" bit is the only one that is turned on. What is even more peculiar is that the error goes away if I manually add an IP address table entry routing node address 156 to my IP address which ends in 156. I've attached a screenshot of this configuration.
If I remove the IP address table entry and set the node address conversion back to automatic (dynamic), the error comes back again. This is without touching anything else in CX programmer and the ETN21. I've spent the last hour looking through all the Omron manuals and have not been able to figure out why this is occurring.
Can anyone here point me in the right direction?
Thanks Sergei, that was indeed the problem. Giving it 1C as the node number made the error LED go away. Funny how obvious the problem seems in hindsight.
Hello everyone, I would like advice on the setup below: CJ2M PLC: 192.168.10.01 (Subnet: 255.255.255.0) ETN21 - 192.168.20.1 (Subnet...
1,890
Hello all, has anyone configured before 2 CJ1W-ETN21 in a single rack? I am trying to put 2 units of ETN21 couple with my CJ2M-CPU33 to act like...
1,284
Hi all, I have a customer that has a series of around 15 Omron CJ1M PLC's, each connected to an Omron NS8 HMI via an ETN21 module. The PLC and...
2,925
Hi, I'm having difficulty configuring the ethernet card on on our Omron CJ2H-CPU66 rack. Using the PLC IO table to configure the ethernet card...
3,679
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
128
