Cams and polynomials
aand74
Dec 2005
Deinze
131
Concerning cams in a motion controller that represent slave position related to master position, I would like to ask if my statements are wright, concerning the internally used polynomial :
1)slave start velocity = 0, slave end velocity = master velocity,
slave start and end accelerations and jerks = 0
--> polynomial 6.
2)slave start velocity = master velocity, slave end velocity = master velocity,
--> polynomial 7.
3)if for start and end point, velocities and jerks are known as parameters, I suppose the polynomial order will never get higher then 7?
Normally a 7th order polynomial is used to specify the jerks at the beginning and end of a motion segment. The starting position, velocity, acceleration and jerk determine the first four coefficients of the 7th order polynomial. The final position, velocity, acceleration and jerk are used as well as the initial position, velocity, acceleration and jerk to determine the higher order coefficients.
There was a thread about this topic years ago. Norm Dzeidic was computed the coefficients for a 7th order polynomial that moved from point to point.
7th order polynomials are very good when there is plenty of distance or time to ramp up or down like in an elevator or high speed train. However the peak acceleration of a 7th order polynomial is 1.875 times the average accelerations compared to 1.5 for a 5th order polynomial or 1.57 for using cosine ramps. The peak acceleration may not be obtainable. Also, the math gets messy.
Cam tables usually use a series of 3rd order polynomials. It is possible to implement 5th order polynomials but they aren't widely used in motion but they are in graphical design.
I should want to create a profile where for start and end point position, velocity, acceleration and jerk are specified.
In my controller I can only implement polynomials of degree six.
It should be possible to compose the profile I want by two polynomials of max degree six.
However I don't know to define the intermediary point (endpoint first curve, startpoint second curve).
Anyone has advices?
I am trying to interface the G315 to a webcam using the camera primitive. Cannot get to first base. What driver do i select for a basic webcam? I...
1,587
hi all, i'm working on a project about PLC(digital cam) and mechanical cam. could anyone pls give me some examples about simple PLC applications...
23
7,178
Greetings everyone, I use MSExcel to generate polynomials based on data I plot, and in turn use this expression as a starting point for...
1,669
