VFD Enclosure Sizing (app)
phuz
Jun 2008
Mohnton, PA
1,044
I wanted to share a simple little application that I've been working on as it's become handy to use this for calculating a minimum enclosure size for drives, instead of doing the individual math every time.
The VFD/Servo Drive list is populated on startup from a csv file which makes it very easy for adding/removing/modifying the database. I still have some more parameters that I want to add, such as temperature deration, vented vs. sealed. If there's interest, I'll make this available for download when those things are added.
Hi Phuz, I would have interest in trying it out whenever you are ready to make it available. Thanks!
What are vertical square inches?
Vertical Sq. In. is basically the surface area of the vertical sides exposed to air. On wall-mounted enclosures, you can use 3 sides for heat dissipation; where as on a free-standing enclosure that has airflow behind it, you can use all 4 sides. Only the vertical surfaces count.
Hi, Never had to put a VFD through an enclosure before. How does that work with a sub-panel? It looks like you would use the gasket/etc out the...
1,155
Is it OK to have multiple Frame size VFD's inside the same enclosure that will be dedicated to VFD's only or is there any code/regulations against...
1,771
Hi all, Does anyone know of a calculator for figuring out size of enclosure to house multiple vfd's? We have a job at them moment where we need...
2,244
I going to be running two drives around water(Fluid test lab). The drives are for a 15 Hp pump and a 3 Hp pump. I will have water flowing over...
3,901
Hello, first of all let me state for the record that I'm not a tech of any kind, I have limited experience with industrial automation devices, so...
80
